i rested the clone and tav assembly on the MX frame. doesn't look like a fit.
the engine is all the way forward and the driven pulley will interfere with
the jackshaft. i can't clock the tav"counter-clockwise" any more as it hits
the cooling fins. the engine also needs to be spaced up to...
any way i try to fit the tav2-30 on a clone doesn't work.
is this the wrong torque converter for a clone???
it only shows a tecumseh in the installation instruction.
:hammer::out:
Brand new never used in their original box
TAV2-30 $150
20 series 75 bore Driver $60
Series A 5/8 bore Driven $70
Buyer pays shipping.
Thanks OldMiniBikes!
TAV2-30, ¾” bore, #35 chain, Cast aluminum back-plate. Includes factory manual and all hardware (pictured). Less than 2 hours use. Plastic cover also included (a bit rough) but not pictured.
$OLD, PF in the CONUS.
Please PM/email if interested.
I went to bolt this up and it's not looking good - Cyl head is in the way. If I clock it down it is lower than the engine - Any ideas? It has the aluminum mounting plate.
LK
Harbor Freight clone that was bought in October but it has MAYBE 2 hours on it because a friend and I decided to buy 4 wheelers instead.
Here is the mod list...
#92 main jet
governor removed
18lb valve springs
AGK filter adapter and k&n style filter
AGK valve cover breather kit
custom...
