First, mount the wheel the right way and see what you have, the hub may be offset. Swapping the spacers would shift the wheel 7mm and I doubt you'd be able to align the caliper with the rotor. If the heads of the cap screws still hit the frame with the wheel mounted correctly, there are a few things you could do: Place a flat washer between the axle spacer and the frame. Replace the socket head cap screws with button head cap screws (they are typically lower profile). Counterbore the bolt holes in the sprocket adapter to partially recess the heads.
http://www.bajamotorsports.com/file...nsim Doodle Bug 96cc Mini Bike (VIN LUAH).pdf
You posted while I was working on this so I know you flipped the wheel, don't feel like editing this post.
