so today i traded a briggs pull start and a used electric starter for a running tecumseh HM80. w/o gas tank, but it ran. the first thing i did to it was put some gas into the spark plug hole and pressed the button, and it fired right up. so i jerry rigged on a 8hp briggs tank and it ran off that.
carb is FULLY adjustable :thumbsup:
my only problem is, its a 1" OD shaft. :freakout:
i guess either i look at a $120 clutch (im broke right now) or i figure out how to turn it down. the best way for me that i know of is starting the engine, and hold a file to the shaft and wait a LONG LONG time. then, cut a 3/16 keyway into it with my dremel. if this works, that would be awesome!
i have no desire to rip apart the good running engine and bring the crankshaft to my local CNC shop. that costs money too....:wink:
so here is my bike and the engine together... to give an idea of what it will turn out to be.
and here is the engine now after i fixed the pull start and freshened it up a bit. just have to get the rust off the muffler and make a adapter to use that air filter...
