my posts from here should be pretty straight forward on progress. ive been working hard to get the frame done and figure out how everything will go together.
mud guard to keep dirt from getting caked on the engine, made from a murray tractor body panel. cut it out completely by eye, then hacked off the extra material. longer foot pegs. plugged fake tank holes. reinforced seat mount with angle iron from a bed frame. also welded the rear fender mounts back on. and ground off the old mounting tabs for the safety guards and exhaust head shield (dont need that anymore!)
this is what i cut pieces off. the murray body..
this isnt the engine im using. this one is an 8hp and i will be using a brand new 10hp but the shrouds off this 8hp.
maybe a crack? i used airplane paint remover (good stuff) to take paint off welds and places i need clean to weld but cant reach with a grinder. wire brush it and all the paint is gone.
i spent a long time holding the rear fender on my bench grinder to get all the paint off. it looks really cool as bare metal but i have to paint it or else it will rust...
uhh what kind of animal would chew through a gas cap? there was poop all over the tank too.
broken mounting tabs from wheelies
ill be using a razor mx500 kick stand because the original never had the spring, so i had to zip tie it up ever since i had it. no other spring i had had the right tension.
this is the engine i took parts off... i can convert to recoil only, buy new coil and carb, then i can keep using this engine in spring.
