that means drive it like you stole it. :innocent:
I don't drive anything like its stollen.
Put a white hat on my and let me lower the seat so I can only see through the stearing wheel and send me down the highway.
Changing oil is important within the first heat cycle where the engine will shed the most metal. It should be a short cycle too.
Change oil often 3 times durring break in.
This is not expensive and its good piece of mind.
Look at the oil, it will tell you a lot about what is going on inside as will the plug and blow by if you are running a catch can.
As for how much load you need depends on the rings and cylinder finnish.
As built clones are not going to break in fast.
If you are running built clone a UT1 piston 1mm ring set and plateu finnished bore then I would be more concerned because you don't have a lot of time seat the rings ( as the machining is so tight they are more or less broken in as they sit after assembly ).
The smartest thing of all to do is strip you new clone right out of the box and checl to see its actualy clean inside and everything is torqued correctly. I find grit inside places like the hollow of the gudgeon pin nd sometimes dirty bores and fall out from material in the plant that wafts around and settles on parts durring assembly.
