Struggling big time. This is our family 1970Benelli Dynamo. Has been back and forth from PA,NJ, NY and now is with me in VA. I did a restore on it the last few months and am beyond proud of it. But.......it starts but doesn't run great. It starts with the choke down and runs ok but has no power. Choke wide open runs with a ton of throttle twist only. Won't idle no matter what. Idle screw is 1-1/4 turns out. Mixture screw is 1 out. Fumbling with these screws hasn't warranted much change. Carb has been off the bike 4 times this past week, every Port and jet cleaned. Float works as it should. 93 octane with 40:1 2 stroke ratio (stp). New head gasket, new cylinder base gasket. No gas leaks. E3 hot spark plug.
