cam choice is dependent on other factors such as intake, exhaust, compression, and head flow. are you asking for a stock engine? Governed or ungoverned?
then a mild cam is what you want. CM is 236 duration @.050. that is about the max you want to go. Black mamba JR would also be good if you can get one. They are 230 @.050 with .275 lift. CM is .265 lift i think.
The Mod2 cam is also a good choice... Always can add a 1.3 rocker on the intake to increase lift... This cam has good low to midrange power and pulls hard to 7500rpm
