big block warrior build
#24
quick question,can you lay a tape measure across your motor W torque vertor on it and tell me what the width is?
preferably With the cover,if you are using one...:thumbsup:
and,what is a 420 in terms of Torque produce?
those belt clutches can handle that?
#25
Ready for this......from edge of pullstart cover to the tip of the crank bolt on the converter is 17 1/4" !!!! She's wide! That's with the converter fully seated on the crank. I may have to space it out a 1/4 or so to line up with the driven pulley, if I push the driven pulley in , it'll hit the head so it'll be the driver that has to move out.
Stock 420 is rated at 18.5 ft/lbs. I'm hoping the 40 series holds up to it
#31
Haha! Nice. So how's it run? What gearing are you using and what mph is it getting you?
That's only a 270cc engine. I can't quite remember my jackshaft gear size. I'll have to count later. I also haven't had an open stretch to really get an accurate top speed. The street I live on has a lot of stop signs, and until now I've only had rear brakes, so it takes me a long time to stop, but I used GPS on my phone, and I got up to 46 before I chickened out, but it was still accelerating.
#32
Got it running yesterday! Still needs a throttle setup, brakes, a fuel tank, and a different header. I shot it down the driveway once with a tank between my legs and a finger on the linkage....then I decided not to visit the hospital
#35
The plate worked great. I've gotta trim it a little to clear a bump in the fan cover.o took the bike for a quick ride. Acceleration was great with the current gearing (14 tooth on jackshaft and stock rear sprocket). I hit 47 mph and was still climbing when I broke something
#36
When I put everything together, I could feel some wobble in the shaft. I think it was a combination of cheap bearings and both bearings being inside the framerails while both the pulley and sprocket hung off opposite ends of the shaft.
