How can people here help you if you won't even say what motor you've got?? Clone, honda, predator there not the same internally.
Isky was on vacation for a month so his stocks were down, hes out of Predator cams right now.
Dave you should try the DYNO 107ss and there recommended springs . You will need right much carb for it . This cam has more lift and close to the same duration as the black mamba , which I don't think is made for a flat head . That dyno makes stupid power .
It was a facetious comment I made after several thousand OHV cam posts. Already had the FH with the dyno cam, and it made great power, as long as you didn't sprain your wrist by cranking it on the spark stroke. And JB, I do want that motor back.
