Update- I was ready to mail the wheels to Markus but thought that after soaking in PB-B for a couple of weeks I'd give it a try using an old favorite long handled thick screw driver with a wrench on the handle for some much needed torque. The screw driver fit perfect in the head slots and with the tire on the floor I was able to apply a good bit of "muscle" to the turn. And it worked!!!! Well, almost. I got three out completely and three broke off leaving about 1/3 of the bolt in the wheel. Today, I carefully drilled the three out.
NEXT QUESTION-- The tires are stuck to the rims. The halves are loose but separating the tire edge from the rim "ain't happening".
Any suggestions? I have used the edge of a reasonably sharp screw driver and wedged in between the tire and rim and slid it around the rim to "cut" the "bonding" but even having done that I can't get through to the inside. I want to save the tires if I can,,,,, but if I can't then I can't. They are obviously old with some cracks.
What can I do to separate the tire from the rim?
THANKS!!!!!
Tom
