I searched, but did not find what I'm looking for.
My brake cable is barely long enough to reach the connector. I have the cable thru and screwed down, but is is not even a 1/4" out of the other side.
So, here's what I need to know.
1. Do I need to shorten the conduit? Just cut off an inch or so and put the metal tip back on? Any tricks to this?
2. The cable is flared on the end from screwing down. When I have tried to trim or re-twist it together it just seems to get worse. How do I trim the flared ends off - maybe hold the good part in pliers so it doesn't untwist or flatten? Can I solder the ends to make a tight end so it goes through the hole easier? How much needs to extend - don't want it to slip out at the wrong time.
3. Any good advice on adjusting the brakes? I either have little to no braking or the brakes are engaged all the time.
Thank you for your help.
