What color or number should the cover have. I'll go dig thru the pile and see if it's out there. As I mention on another post this engine is from an estate of a gentleman who repaired small engines.
Thanks for the help.
:laugh: It doesn't really matter.. The one that is on it will work fine.
If you have access to 1/2 dozen of them laying around you'd be looking for (paint and petina ) matches the rest of the engine.. It'll look just about like the one on it, but match the rest of the motor better..
Then... The numbers, OH god.. :laugh: Uhhhh lets see
It's going to start out 80 (cubic inches) First two digits of the model are your CI displacement, why it's 80 and not 08 is a mystery to me but :shrug: It's not 80 CI :laugh:
Then ya have a horizontal crank shaft, so probably 0
Then ya have a ball bearing PTO so thats gonna be 3
Recoil start 2
Then type number is usually giberish and can't make heads or tails of it.. :laugh: So like ??????
Then your CODE I'm gonna call 87???? 8 something.. because it's probably around 1986 and the first two digits of the code are year it was made..
SO MY guess is gonna be like...
MODEL 80032 TYPE ?????? CODE 8721212
:mellow:
Heres the Secret Decorder Ring.. :laugh:
http://www.outdoordistributors.com/Briggs_And_Stratton/briggsmodelid.html
Lookk for one the same color, condition, sticker styles.. And look at the side of the shroud, about where the carburetor would be bolted to the block.. And your nubers will be running along the edge of the shroud..
Something in the ballpark of
