i have a 5hp briggs funpower that i turned into a raptor with a raptor piston 107ss dyno cam, stronger valve springs, billet lifters, rod and flywheel. as well as a header and a boared out older style pull choke 3 bolt carb pulsa jet carb. the pull choke has been removed, butterfly now opens fully, the butterfly shaft has been thinned down and im still running pump gas, the stock jets were never opend up to run alcohol, at my request. im having troble with the carb it isn't jetted right. it runs to lean at idle and to rich at full speed. i can get it to run well at full speed or at idle but not both. iv never messed with the jets before and would like to know how to get to them and change them. preferably with pictures. I eather need to open up the idle jet or close off the main jet. eather way should have the same effect. also i have a stock newer style flip choke, fixed main jet pulas jet carb with an idle ajustment screw. it seems a little larger than the board out carb but not by much. would this carb in stock form flow and run better or worse than the older style carb i have (after the older one was re jetted)?
