That is a 13 cubic inch - 5hp motor. You state 130502, but the 5 means that it is a vertical shaft mower engine? Your motor is a rubber seal type on the end on the crank (not bearing)
If you go by that chart it means someone swapped out the shroud on your horizontal shaft engine with a vertical shaft engine and those numbers are now worthless.
