It’s been a while but I’m back. More parts came in - black mamba jr., 26# springs, raceseng S1 push rods, ¼” guide plate, 1.3 stamped rockers, and a 18cc head.
Installed the cam, lined the dots up on the cam and crank. (Although I don’t recall if I made sure it was TDC, if it was not can the cam be installed 180 out?)
Set the valve lash at what I believe was TDC. My feeler gauge only went down to .004, so I used the side wall of a PBR can. (I am picking up a better feeler gauge tonight to recheck the lash.)
It didn’t want to fire without giving it a little gas. With choke on I got it to fire, but it didn’t want to run with the choke off.
Suspected too small of a pilot jet. I swapped jets - replaced the stock #15 pilot jet with a #17.5 and swapped out the main jet that was a #95 but I drilled it out a bit (have to go back and check how much tonight) to a #130 (which may be a bit much, might put a #125 in it, I have one in stock).
Now, it ran at an idle. But the idle was still high, I screwed around with some screws. The screw on the bottom of the carb (which AGK indicates is an air screw
https://www.affordablegokarts.com/carburetor-tuning.php ) I got it idling lower, but to low and it would stall (didn’t seem low enough that it should have stalled though). I found another screw on the side of my fakuni, turned it 1/8 of a turn counter clock wise and the idle smoothed out to just around 1600 rpm. Does anyone know what that screw on the side is?
I seem to be running a little rich still….(haven’t moved the needle ring since the cam install, had it goods and dialed in prior to this, might need to lean it out a bit there). And I noticed the occasional back fire on sudden off throttle…
But I have a bigger problem. This thing is an SOB to start; it still wants someone to work the throttle a bit while another person pulls. My arm sore today from pulling last night (no kick back though) lol. I’m wondering if its timing related, or if the higher compression head created an octane sensitivity issue 65shelby clone mentioned. (I’m not sure if the black mamba jr. would be considered a mild or lump cam.) I’ve only run high end pump gas in this motor, no race fuel yet.
If you can get it started it sits and idles, and revs just fine, no bog no lag.
I have an ARC billet flywheel, replaced the stock key with a 4 degree key. I ran that for a while with no issues before the cam and head upgrade.
My throttle cable broke last night in the middle of playing with it… so I’ll grab a new one on the way home and continue to test and tune this evening.
Thoughts? Comments? Thanks in advance ;-)
