Yeah, thanks Pete. FMTT, I only spent a half an hour researching Doug's question.
It's all on page 3, before comments about cutting off fins came in to being.
To clarify six volt head lamps- I said that with regard to the tiny charging systems with no battery, no biasing diode, where the maximum voltage is 10. Use 6 volt incandescent bulbs for that, and 12 volt tail lamps for that.
In Doug's case with this engine, it's all 12 volt, all the time. I referenced the part number of the alternator and the reg./rectifier.
By the way Pete, your questionnaire is incomplete. You need to add "Hand Warmer" Y/N. From the various schematics I was researching, they are by far the highest loads.
Good job on describing voltage as "electrical pressure." Amperage is what happens when you turn on the tap and it flows.
