carb issues.
i have a genuine honda gx160 carb that im using on a HF 6.5 clone, reason for that is because the carb that was on that clone before would not stop leaking for nothing, so i used the 160 carb hoping it would work better.
now the clone wont start, any ideas?
i believe im using a #90 jet, with a header and air filter, the governor is also removed, and has 18lb springs.
i did pull the low oil sensor out this time while it was apart, and since i did that it wont start, could that be a reason?
