ugh how can I tell if it's upside Down I can see the little notch for the screw driver It fits but the jet will not loosen up for some reason
To me it sounds like the carb is like the Predators' , so..
Assuming the carburetor is
on the engine,screw the jet to the RIGHT. Not the left.
If it's off the engine, with the bowl facing UP, THEN you can turn screw the jet left to loosen it.
I think the first time i ever took off a jet i had to use vice grip pliers on my screwdriver to get it out. Just be very careful not to scrape the threads with the screwdriver.
