Cheap, quick way to clean up carbon build up in combustion chamber and ports?
Like Rocky Balboa, I'm stupidly getting back in the ring with a Tec OH60. Decided I'd rebuild from ground up--was an oil burner and I need to clean up the head and exhaust ports. Anyone have any suggestions for cleaning all the carbon build up out without access to a media blaster? I'm a little nervous using anything stronger than a soft wire wheel to get the loose stuff out.
buckeye
Be careful.
No lifting.
I use the wire wheel method and have had no issues.
PB Blaster sounds much easier.
Thanks for the tip.
