Do I need to move the engine to the right? I worked hard to center the rear wheel, which included placing a spacer in between the drum and back plate. So, I would rather not move the wheel out to the left. If I move the engine, should I order an engine plate before the re-location? or just cut into the existing engine plate?
The bike is a Manco Streaker (so things are tight on these little buggers), with HF Predator 79 cc, 6" tri-star wheels, drum brake built into the sprocket (or vice/versa).
If the consensus indicates that I need to move the engine, please advise me on the best known methods.
Take care!
Take care!
