I have this little generator with the Walbrow bowl carb on a 3.5 horse flatty.. It uses a nice aluminum intake manifold.. Problem is the main jet is not adjustable, and if I want to use the generator, I gotta wire the choke like EXACTLY 23 / 59 shut, or it won't run..
The power went out, and I decided to fix my carb...
after digging some, I found a jet that was almost perfect..
It needs to be very short, as it will crash into the emulsion tubes in the carb body after like 4 or 5 threads.. It needs to be short, and fed from the bottom sides.. Like a tecumseh HS jet only shorter..
This is a pic of the inside of the carb before, all the parts laid out, the adjustable jet I plan to use, and a toothpick broken off into the original fixed pre-sized jet, I plan to use to cork the original jet off..
