I just got started myself. If I had the money for a JD Squared, that would have been what I got. I had to keep the cost down because I had to get some other things (welding items, etc).
I ended up getting a hydraulic bender from Northern. I am very happy with it (for the price), but it takes some extra time.
I pack the pipe full of sand before bending. It has helped tremendously to keep the bends from deforming and flattening.
I start by taping one end of the pipe with 3 or 4 pieces of duct tape. Then I fill the other end using a funnel. When its full to the top, I tap it on a block of wood to get the sand to settle in. That sand level will drop a little as it compacts, so I top it off and tap it again. I do that one or two more times until it does not seem like it is going to compact any more. Then I tape the top with 3 or 4 pieces of duct tape and then proceed with the bend.
Like I said, it takes a little longer, but saves you several hundred on a bender that in my case won't be used too awfully much.
One thing to keep in mind is that most of the hydraulic benders have dies for pipe (measured on ID) so if you plan to use tubing (measured on OD) you may not get as good of results. I've been using pipe, and have not tried tubing.
Let us know what you get and how it works out. :thumbsup:
