I made a couple custom headers with mufflers. They fit nice under the seat, between the frame rails and above the rear fender on the DB-30 with the 6.5hp HF/clone/Honda GX engine. I started with 2 of them if I get a positive replys I will make some more of the same design with the straight tip. Replace that brick bolted to your engine. here's the deal
parts used:
AGK (affordablegokart.com) CNC'd exhaust flange ($14)
.065" wall 1" OD mandrel bent pipes cut and MIG welded together ($22)
Briggs 8hp muffler ($8)
reiforcing strut ($1)
The parts cost me $45. It takes me about 3 - 3 1/2 hours to cut, fit, weld, grind, sandblast and paint them. Each pipe is $85 + shipping.
The 1st pipe is a bit tighter to the frame and should be used with the 3/8" adapter plate. Without the plate it will clear but it's tight. It's the one with the curved tip off the muffler (pics attached to this post)
The 2nd pipe will fit with or without the 3/8" plate. I made it with extra clearance. It's the pipe with the straight tip (pics attached in the next post)
Let me know what you think
Thanks everyone!
parts used:
Thanks everyone!
