Well after posting all sort of questions about making mods for a larger engine and tav2 I finally got my db30 done. I installed a Honda gx 120 and tav2 on it. Originally I was going to put a 6 robin in it (had it in for a while) but came across a good deal on a gx 120 and decided to put that in instead. The bike goes plenty fast and has enough torque to put me on the ground (220 lbs). I ended up raising the engine with 1" square tubing and fabing a new engine plate. After I had the engine in I noticed that there was not much peg left so I extended the foot pegs 2" and raised them up 1" on the frame. For those who are wondering the gx 120 and the 6 robin matched right up with no problems.
Also in case you are wondering its a lot easier to put a tav2 on a baja mini than a db30, the baja min needs no fab except cutting the tav2 off on the bottom. Same engine mount work fine and I was even able to use the same chain.
Thanks for all the info and pictures, sure make things a lot easier with this site. I am going to attempt to put up some pics. These little mini bike are great and I can not wait until all the snow is gone.
