I made this tank from a old propane bottle, the fill cap is from a tin container that had a metal screw cap, it's just soldered on. Capacity is 1 litre approx.
The brass 1/4" compression fitting is soldered in too, tank is vented though a small hole in the fill cap with hole in the gasket underneath offset to keep dirt out some what.
The whole thing is held in place with a hose clamp and 1" angle bar support.
There are some rubber spacers to square it up.
I like it cause it gets the ugly big bulky motor mount tank outa there.
