The HF 6.5's come from the factory lean and easy jetting changes can make them run much better.....even when stock. You must change the main jet when replacing the stock air filter housing with an open air filter like a K&N or UNI filter.
You can replace the jets with larger ones or purchase small # drills. A complete set of #61-#80 drill cost about $12, or individual drill can be purchased for about $1 each. These drills are tiny and must be treated gently. The jets are brass and drill easy but take it easy!
Opening up the idle jet can make a stock engine start easier and reduce popping while decelerating. In this DIY I will show the steps required to re-jet your carburetor.
Before starting make sure there is no dirt at all around or near the carburetor before working on it.
Most all new HF 6.5 engines have a cap over the idle speed screw. Use a pick to pop it off, it comes off easy. Thread the idle screw out and then with the pick remove the idle jet.
