Doodlebug 6.5 engine swap kit
cjtmini
I would like to get your HF 6.5 swap kit as well; I have the HF 6.5 and the DB, but need the rest, including the mounting plate, DVD etc...if you still have available. Please let me know how to contact / send. I'm in MInnesota....55082 Thanks!!
If you guys had a clue you would not need a kit. just engine and clutch.
What is the difference between the kit Chris sells and the one Promodraceparts sells. I see Chris plate is not slotted where the the Promod one is slotted in both directions fore and aft and left/right. Prices are similar ?
Thanks
Smokie
Perhaps a pattern should be offered - say $5.00 for those that wish to make their own plate. I for one like to make what ever I can and certainly a plate with 8 holes in it that are counter sunk is within my grasp and certainly not worth $40.00. Al flat plate 3/8' plate at the metal shop is a couple of dollars and Chris I believe noted he thought it would take a hour to lay out and drill time - certainly not worth the $38.00 - just my opinion. But for those that don't want to make one then the kit from Chris is the way to go and be up and running in no time.
