I wanted to be able to see the shiny new Astro mag wheels I got so I drilled my sprocket with five 1 3/4" holes.
Has anyone else done this and can I expect it to hold up to trail riding?
Also, has anyone polished these wheels? How do they look when polished?
Since the picture was taken I have mounted another bearing in the center of the sprocket and I am going to run a spacer between the bearings.
Are you supposed to run a spacer between the bearings inside the wheel like on a motorcycle? If so, where do ya get them?
One more thing..... can ya get a 1/2" ID - 5/8" OD sleeve to adapt these 5/8" bearings to a 1/2" axle?
I know it would be easy enough to swap bearings, but I see my Sears Roper was done this way from the factory and it would allow me to swap the wheels to other minibikes quickly.
