You would have to rebuild it.. Loss the plug at the end, get battery, clips and a new push button. Just bypassing the stock plug and button. Work. but can be done... go for it.:thumbsup:
He is taking about converting a 120v ac starter to 12dc it can be done but the whole thing has to be redone not just removing the pug and changing it to battery terminals.
you could change a 120 v in to a 12 v motor but its not going to be easy or fun . depending on if its series or parallel wound it will turn on dc power ,weak as all hell but will run . you would have to rewind the armature ? the center rotating shaft , i never seem to remember the correct term . for a heaver gauge of wire and reconfigure the fields .
would be easier to take a briggs starter and reconfig the mount and shaft to fit , i would think .
