some of you may remember a month or so ago i was talking about fitting a 13x5-6 rear slick on my Cat. since it wouldn't fit on the 3.5" wheel i was running i decided to get a spacer made. after lots of "it will be done in a few days" i finally got it today. it's made out of aluminum and is actually kind of heavy (probably weighs a bit over a pound). i'm thinking about drilling it out some to drop a bit of weight from it.
i got the wheel together (only took 40 minutes, don't ask) and mounted in the frame. there's no air in the tire in the pic because it's too fricken cold to go air it up at the gas station. you can get the idea though. it's not nearly as close as i thought it was going to be. my wheel/tire are pretty much centered now (was way to the left before) so i'm happy about that. hopefully i'll have it all together and rideable by sunday. the only thing i'm waiting on now is my header. i still need to attach the tank, tune the carb, adjust the clutch, make a new chain (switched to a 60t rear from a 72t), hook up the throttle and kill switch and i'm sure there's some more little things.
it's been about 5 months since i've ridden this thing so i'm happy it's finally getting back together again.
pic time!
pic time!
