No, it will be gravity fed... As long as the lowest point on the tank is above the fuel inlet on the carb you will be ok and as long as the fuel line is on a constant downward angle before attaching to the carb....If the fuel line comes off the tank and goes back uphill at some point you may want a pump, try the bike first, if it starves for fuel install a pump..A fuel pump is never a bad idea, just not always needed..
