1. A flat motor is more compact [less volume], fits in more places.
2. " " has fewer parts. More reliable, easier to service, cheaper to fix.
3. " " does not have to rely on oil 'mist' to lube the valve gear. No vaccum hose to carb.
4. Air cooled OHV engines have a problem with head cooling because the valve box prevents a large area of the head from being cooled. Hopped up OHV engines will suffer durability problems that the Briggs style will not when ran hard for an extended time, not just a 20 second burst.
5. A flat motor weighs less.
6. " " can use a syphon type carb because the carb is high enough to get the tank below it. Syphon carbs cannot leak gas on the floor [due to a stuck float valve] and burn down the house/shop. And the straight carb is a LOT more reliable.
7. A 6.5 HP clone OHV does not have a performance advantage on a 5 HP Briggs in stock form. In fact there is a big body of evidence that the Briggs is faster. Ususlly when you hear the clone being bragged up it is a comparison of a new clone and a well used Briggs that often is really a 4 HP!
8. The fastest, meanest, most highly tuned, highest out put small engine of the type we are talking about here is the Briggs style, not OHV. If you don't believe that take a look at some JR. Dragsters.
9. A clone looks like a piese of Asian junk....IMHO.
10. A clone devalues any vintage mini it is put in.
11.
12.
Ther are more reasons to say that a flat motor will not go away any time soon.
