Good to be back in town
Business trips suck! They take you away from the important things in life, like your first mini bike build.
On the plus side, most of my parts arrived while I was gone! I spent awhile yesterday pulling everything together, and I now officially have a fairly complete rolling frame.
The first order of business was the tires - no problem there, new tires and tubes, all good on that end. The wheel bearings are still in awesome condition too.
Next was the rear shock, which was the most interesting challenge. To start off, I cannot tell if I need any special parts to properly mount the spring - so I simply just threw it in there and wrenched the mangled stop strap back over it with a c-clamp. Eff it.
If it becomes a problem, I'll do it nicer and proper, but for now, I rolled up and down several bumpy hills and the spring performed perfectly.
Unfortunately it's a bit soft, being only a 200lb spring, and bottoms out without too much difficulty (I'm 160lb.) I'm going to need to buy a heavier spring, or if I have to, a second, smaller inner spring. Either way though, it was a success, and it feels great to have a very smooth rolling frame.
At this point, I ordered a torque converter from the warehouse (the Comet 30 clone). I'm going to try and make the existing pulley/10-tooth sprocket work, but if I can't I'll have a backup.
The other bit of fun I face now is mounting the engine. The great news is that I don't need spacers. As suggested, I replaced the "manifold" with a header, and I've got more than enough room now. Unfortunately, the prefab header is hitting the frame, preventing the engine from mounting at the correct angle. If I can't bend it to the way I need it, I'll simply have to make my own. Should be a small issue to take care of.
Overall, good stuff all around!
