My engine would run somdays and not run others. Or it would run and then die in ten minutes. After going crazy and not wanting to buy a new carb i found out that the stock gx200 carb has a second bowl on it. It is underneath the fuel on/off valve and simply screws off with pliers or a 10mm socker(i think its 10mm) When i removed this bowl i found it to be filled with metal shavings, dirt and goop. I cleaned it out, put it all back together and now my engine runs like a champ. It is getting way more fuel then ever before, ESPECIALLY at top speed. This was the cause of all my carb problems. NO ONE has ever mentioned this second bowl on this forum(at least i have never been told and i have asked for help many times) If you are having carb issues, i would take a look at this and see if it doesnt solve them.
