gx340 gx390 346cc predator stud bolts help.. general questions..thanks
I have a few questions I hope you all can help me with. I have a 346cc predator. The 346cc predator is pretty much compatible with all gx340 and gx390 parts right?
Does anyone know where to order the stud bolts and which ones for this engine for mounting a billet adaptor and air filter?
Does this engine require a choke hold?
I have been getting different opinions from on line stores on which jet to buy and install once the air fillter and new header is on. One said #98 others said 110 or 112. Anyone running a gx340 or gx390? Which jet size did you find to work the best?
Does the throttle linkage kits for the 212cc work the same for this motor?
Thank you for the help!
