Hi all,
I was able to grab this Heald Bronc this week. It was advertised as a Super Bronc with a 10 HP motor. It came with what you see in the photos as well as some NOS cables for brakes and throttle as well as an original fender, seat, screw in muffler, and some other brackets for a plastic gas tank. I was able to score this for $250 and I am trying to figure out how much more I will need to pour into it to get it restored to like new condition with correct parts.
So far, I have determined that the motor is a HM80 155042A Tecumseh; I think this is a 8 horse motor, if so, is this the correct motor? There is a torque converter on the left side with a clutch brake set up for braking.
I haven't had much time to look it over yet for a serial number on the frame, but I plan on taking a bunch of photos to help with identification this weekend.
My goal for this weekend is to figure out what parts are needed to get the motor running (and find out if it runs). To do that i need to do the following:
1. Figure out how the throttle assembly is hooked up and if I have the right parts to connect everything correctly; if you have one of these motors, detailed photos showing the assembly would be greatly appreciated.
2. Figure out what parts I need to acquire to get the carburetor assembled correctly; right now there is no air-filter or anything on the intake side of the carb. I'll take some pictures showing where that is at.
3. Figure out what parts are missing from the exhaust. More pics will follow of this area.
4. Figure out if the plastic gas tank is good and if I need to get new fuel line and how to route it.
Anyhow, I'd appreciate any/all info on what model/year this appears to be based upon the frame/motor as I'd like to do this one some justice in restoring it.
