dose anyone know how to remove the engine mounting bolts of the DB-30? If so how did you do it? Did you have to use a power wrench or what? and what size are the bots?
you just turn them with the little wrench that came with it it should be 10mm. and remember left loosy and righty tighty gets all up side down and backwards when the bolt is up side down.
and make sure theyre tight when your done doing what ever last thing you want is that engine coming off and landing on your foot. or just sliding around
I apologize shark,I thought you were pulling our legs.Hope you get everything figured out.Do you by chance have a friendly neighbor that likes doing this kind of stuff? He may be able to help.
