well i took the dooglebug out for a 2 hour offroad ride today and it was pretty much terrible. i knew it would be but didnt think it would be that bad. i ran 20 psi in the tires though for most of the ride and after letting out alot of the air although steering felt heavy and weird it was softer to ride. so i got home and decided to make a suspension fork for it. i got a bicycle fork and was planning to scratch build a new fork and keep the original fork intact but i got too lazy and didnt have steel so i modded the stock fork and stuck some suspension legs on and welded it all together. it works pretty well and with the tires full of air and the bike steering well too.
the engine has a header, 8 degree advanced timing and a gx160 head. soon to come is a 90 size jet, gx140 emulsion tube and a high flow filter because i want more power.
another thing im planning to do to the frame is move the foot pegs behind the engine plate so its alittle more comfortable to ride and so if i ride through something rough i can stand up and soak up the bump.
now for pictures, here is what it loked like when i got it, i was planning on keeping it stock and just riding it around but that didnt last long.
and here is some build pics of the fork and the bike overall. it has the honda gas tank because the cap seals better. and im going to paint all the grinded metal after i finish modding the frame. also there is an extension added to the rear fender because its not long enough and when you ride through water it goes all over my back.
