Alrighty guys. I figured id tell you the story/ plans and you can just jump in as i go with comments and things im missing! Thanks in advance
I got a gx160 tonight with extremely low compression. Took it all apart and noticed slight scoring on the cylinder walls and piston skirts. So iv decided to bore .20 over. I plan on using an oem flat top pison along with the .20 over ring set (both from OldMiniBikes warehouse). My first question is can i use the oem piston pin and clip or is there a special one for a .20 over piston? Next is the head. I plan on buying the oem 14cc full dome head that comes bare. Can i use new oem valves, seats, rocker arms? I will of course be using heavier than stock springs due to the governer being removed. Am i missing anything so far? And is there a such thing as a .20 over head gasket or does the oem one work?(want to use a gx200 head gasket as they are thinner than gx160 gaskets) As for the rest of it i believe i know what im doing. Just carb from OldMiniBikes that's "performance" along with a cone air filter and adapter. Then a billet flywheel.
Please chym in on whats missing on my parts list or anything else you may think. Thanks
