has anyone had any experience with this piston I just got one in for my blue greyhound 196cc clone and have searched a lot and the only thing I can find is that I should stagger the rings 120 degrees... ok got it. but the two top rings (the thicker ones) neaither one has a lip like I am used to seeing the shiny ring seems to kinda have angle on the inside my question is how should I install the rings for that piston? also the piston does not have an arrow which I think is supposed to be in the lower part of the engine as in closest to the bottom. I have put the piston in to the best of my knowledge so far and it was a very tight fit but however is 1000x smoother to turn the engine than with the factory piston so once I get this ring thing figured out and my torque wrench comes in i'll be on and put in a review but from what I noticed so far not only should I get the better compression which hopefully gives me a bit better takeoff but with how much smoother it now rotates I would imagine I will notice an extra few RPMs (aka an extra MPH or two). thanks guys
