Also would I be able to engine swap with this predator engine?
The pred 224 has a wider blower housing, recoil cover and starter cup.
This will make you loose some of your right foot peg.
If you want the headlight to work, you can change the old, charging/lighting coils, and flywheel from the old engine.
You can change the blower housing, recoil cover, and starter cup too.
Also the stock tank on the 224 has the fill cap in the middle of the tank, that's gonna make it really hard to refuel.
I can't see in the pics, but you MIGHT be able to change tanks too. Depends on the front tank mounts on the old engine.
