Here is the setup. Anyone have an idea of how much HP this produces? This is my first build and its going on a bonanza bc 1100. Also what do you think my max speed will be with 14" tires and a 12 tooth clutch with a 72 tooth sprocket?
ARC billet rod
ARC billet flywheel
Honda flat top piston
File fit rings
18 lb springs
Retainer and keeper set
.275" lift custom ground cam
22mm mikuni with pulse pump and UNI filter
mikuni fuel pump
2 stage header
ARC billet rod
ARC billet flywheel
File fit rings
18 lb springs
mikuni fuel pump
2 stage header
