and here is what the math looks like, if you want to play with it yourself (i like the gear ratio calculators, but dont mind doing the math myself, also... you can play with the gear ratio calculator if you dont want to figure it out yourself... and then do simple math to get an approximation of your top speed and at what rpm etc, if you want:
gear ratio calculator and speed calculator here:
AGK - Gear Ratio Calculator - Affordable Go Karts
to get your ratios:
teeth on clutch= 10, teeth on input/jackshaft =20, take that and 20 divided by 10 = 2
teeth on output/jackshaft= 10, teeth on rear sprocket= 50, take that and 50 divided by 10 = 5... take the two answer and multiply them together=
10 to 1 final gear ratio for that gear setup
anyhow, your tire height of 19":
[19" times pi (3.14)] divided by 12" to get tire circumference in feet =
4.97 feet (rounded off)
for your rpm, i based that on reverse math and your estimated speed... for rpm you can estimate what your top rpm would be on your bike, or like i said, buy a tach, but plug in the rpm you would like the motor to spin to, or what you think the motor is capable of spinning to... i choose 7500 and 8000... ill show the math for 7500
with your goal of 7500 rpm:
take 7500 and divide it by your gear ratio to get your WHEEL RPM... 7500/10=
750
to get how fast your wheel would be traveling based on its size you take the wheel rpm and multiply that by the tire circumference in feet. 750 x 4.97=
3727.5 is how fast your wheel would be going in feet per minute
take that number and multiply that by 60 to get feet per hour 3727.5 x 60=
223650, this is how many feet per hour you are traveling at 7500 rpm
to break that down into mph divide it by 5280 (feet in a mile). 223650/5280= 42.36 mph (rounded off)
so at 7500 rpm your bike would be traveling approx.
42.36 mph
not that you asked, just felt like typing that to show you i did the math required to make my assumption
