shortblock/parts lot for someone wanting to do some building. these are the parts from a swap I just did, I changed the block/piston/rod out on a bike a recently bought becuase it basically needs honed or bored out, it ran killer, but was blowing smoke. the block itself other than that shows really nice and clean, no broken fins or buggered threads, was not leaking oil or had been opened up and played with until now.
cam is from this block (1973) stock HS40/50
crank is a 1969 formt he other block and is nice and clean, but does not have a drilled and tapped hole.
sidecover is from the 1969, and is very nice and clean as well with clean gov assy. comes as seen as well as the correct sidecover bolts and a useable but dinged breather too.
$55 shipped for all parts usps flat rate
