I know from racing OHH engines, that imcreasing the exhaust valve size did result in lower bottom end, especially on tighter tracks. I had a couple of heads that were ported, had good valves and springs, and even one with a welded up chamber for more compression, that I used on smaller tracks.
These engines are drastically under square with the big bore and short 1.938 stroke, which by itself hinders low end torque.
I agree with Delray that building a stock or even slightly warmed over engine, the small valves might even be a good thing, especially for a heavier bike/rider.
Here is one of the stock valve ported heads I used to run. That head still made great power even having the small valves. In fact, I patterned the chamber the OVRM head on my 356 build after it.
