So I installed a hydraulic brake kit from hotrodmini and installed it with a couple washers to space it out a little bit which it needed. Brakes work fine till you hit the lever once and the brakes pretty much drag / stay engaged till you tap the lever again. Also maybe worth mentioning when pushing the doodlebug backwards it locks up the brakes too... Any suggestions
