I/C 5hp vs stock 5hp
6doggie3
Without the fan shroud how do you tell them apart?
What do have to look for since most shrouds interchangeable?
CarPlayLB
Ya can't! Easiest way to tell is the iron liner in the cylinder. I/C is iron cylinder, the others are aluminum. Sometimes you can verify that through the spark plug hole. Take a small magnet and see if it sticks to the edge of the cylinder...just make sure it does not drop down in the cylinder! Best thing to do is pull the head! I/C came as all bushing, bushing with PTO ball bearing, or all ball bearing.
MCF2891
You should be able to tell it's an
I/C if you see that little cover on the front of the block right?
cause I never saw that on a regular 5HP Briggs before.
Sent from my HTC Desire 626s using Tapatalk
125ccCrazy
if the step on the crank on the clutch side is 7/8 and not 1" it's a dual bearing...as far as I know I/C were all dual bearing, I/P were bushing block with a bearing pto cover, both of those were steel bore...
CarPlayLB
I have an I/C block with a flywheel side roller bearing and a bushing side cover with a 1" crank. I have another I/C engine that has a bushing block with a roller side cover. The possibilities are endless!
MCF2891
My I/C has a 3/4" shaft with dual bearings. I didn't even know they made 7/8" shafts
Carplay has it again the only way ive been able to truly tell is pull the head and use a magnet carplay knows his stuff
