I would disconnect the throttle and try moving the lever on the engine,see if it snaps back after open it up, if it does i would look into your throttle its self,it may be binding at the bars or its too tight , i would lossin it up ,or maybe even open it up and add a touch of wd-40 if its binding at the engine lever add a touch of wd-40 there also,you dont need much,
as far as it dying out, its been rumored that sometimes the factory puts the carb gaskets on backwards, if the gasket is on backwards were the carb bolts to the engine it will close off the air passage , check out all the gaskets and just be sure they arent blocking the air holes, the factory does hundreds of motors a day im sure and its an easy mistake to make,
