Hey guys I have a semi-built 5hp Briggs with a pull choke carb. I milled the head .30 cut the eyebrows. The engine has a custom ground cam in it. First off it is very tricky to start sometimes and even if it's been running it (and hot) will only start with full choke. Once I get it running, it'll run perfect for about ten minutes then flood out and stall and then it won't start back up. I don't run an air cleaner right now, but looking into the carburetor it is saturated with gas. Also when it stalls out the outer of the gas tank has gas all over it like it burbed or something. Can I use a raptor carb with my tank? Or do I have to go with another pull choke carb?
