I keep having trouble with my scratch built mini bike throwing the chain. It usually only happens when I give it full acceleration. I have done all the usual - aligning, tightening, etc. It will stay on fine as long as I just start slow and go about half throttle.
I bought an idler pulley, but there isn't a good place to mount it. I'm still considering that.
I wonder if the engine plate is flexing because you can see the slack in the chain come down hard when accelerating, so maybe I should weld a support under the 1/8" tread plate to stiffen it?
Would I fix the problem by replacing the clutch with a torque converter? I am using a HF clone 212 engine.
If I could fix this problem I would really enjoy the bike!
Any help is appreciated.
